Sorry but I have this problem with the above mentioned model and I can not find this model on this page......When the maschine is filling with water in the beginning of the rinse cycle; just before it is full it will stop and the lights will blink and a fault number will display in the window of the timer. I think it is F3. When I switch the maschine off by turning the knob and then back on again the water will run for about 15 seconds and then the wash mashine will work perfect
SOURCE: "tap water closed?" message
Plug off the wall. Check the inlet tubes into your machine (after shutting off wall valve) for any blockage or clogging, both ends of the pipes. Refix carefully with correct threading. Turn on before next wash fully; and after wash turn off valve. It could also be that your wall valve is not on fully when you begin your wash.
And dont forget to rate me pl.
SOURCE: Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
SOURCE: Hi, we have a Classixx 1200. It will not switch
YOU WILL NEED A NEW HEATER NOT EXPENSIVE QUITE EASY TO CHANGE
SOURCE: After washing a load of laundry, a light came on
Welcome to FixYa.
The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
What you may have is either a clogged pump, improper detergent being used, ( must use "HE"/lo-sudsing detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely.
You haven`t mentioned if you`ve checked the pump.
Anyway, here`s the most likely way to remedy a E13 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
macmarkus :)
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Thre washing machine is stopping on rince, the light is flashing. we press start again and it goes through the same routine till it hit rinces and stops. the clothes are still full of water, we have to move the dial to rince and freshen up to finish the wash. any ideas..?
Bosch WFT 2830 blocks on the rinse cycle. No errors, no reactions on Start button. Mashine unfreeze only unplug then plug back elecricity power.
After that programmed cycle will continue till the end.
