SOURCE: Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
SOURCE: how do you load a Daisy model 99 BB gun?
Unscrew the barrel insert from the barrel and pull it out. There is a sliding tab that you have to slide towards the end of the barrel insert so that it can be loaded. On the smaller side of the insert, about half way down is the loading hole. Fill with about 20 BB's. Release the tab and carefully put the barrel insert back into the barrel and tighten till snug. Should be ready to go.
SOURCE: Daisy BB gun Model 1894 won't ****
If you need a repair manual contact me. I purchased one a year or so ago to make repairs on a couple I had and have since scanned it in to my computer so it can be emailed out. It's a big file. If you're interested let me know.
SOURCE: 1960's Model Winchester 1894 BB rifle doesn't
Here's a link to download the repair manual. Good Luck!
http://rapidshare.com/files/373685988/1894_Manual.docx
SOURCE: My daisy model 99 bb gun does not shoot bb's with any force.
Try shooting a ton of silicone oil into the oil hole on the side of the barrel and then leave the gun sitting on its muzzle over night, then in the morning with the barrel out dry fire it a couple of times and then try it. what this does is expand the leather seal and bring back air pressure. it worked on my 99, good luck
