SOURCE: 2003 Harley Davidson FLHTCUI Electra Glide Ultra
You cannot, unless you have the Screamin Eagle Race Tuner (SERT) or you take it to the dealer (at about $80/hr.) Sorry I don't have better news, hope this helps.
JP
SOURCE: 2005 Harley Davidson FLHTCUI Electra Glide Ultra
To adjust the clutch, first find the clutch cable adjuster. It should be somewhere along the downtube of the frame in front of the engine. Slide the rubber bellows cover either up or down to expose the adjuster. Loosen the lock nut and turn the adjuster inwards shortening the cable as much as possible.
Remove the Derby cover from the primary cover. In the middle of the clutch assembly is an adjuster bolt and a lock nut. Loosen the lock nut and turn the adjust inwards until you feel a resistance. Don't not force the adjuster, go inwards until you feel the resistance of the throwout bearing on the other side. Try it a couple of times until you get the feel of it. Go inwards until you feel the resistance and then come back out 1/2 to 1 full turn. Lock the lock nut down and replace the derby cover.
Then go back to the cable aduster and and adjust the cable adjuster out until you have about an 1/8" freeplay at the lever. Lock that lock nut down and reposition the bellows cover.
Good Luck
Steve
