If it is electronic, you can open it with a rare earth magnet.
Google
open sentinel safe with magnet
If it is a traditional dial, you will need to contact sentinel, with the serial number, a cheque for $25 and a sworn affidavit that the safe is yours.
In cases where you think you can't remember a combination, it should be kept in your wallet and perhaps coded, add one number or 2 numbers to each of the numbers in the real combination.
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
Press the "PROG" or "P" key again on your Sentry safe's keypad.
Enter your safe's five-digit factory code.
Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
Retype the user code to verify it is working, and then close the safe.
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
Note: Assuming the safe can be opened following one of the techniques in the video, a new battery / batteries should be installed before resetting the code. (Also, I understand the batteries should be replaced regularly to avoid the battery / batteries becoming depleted and causing problems in opening the safe.I suggest replacing the battery / batteries once a year - note the date on a calendar you will look at regularly.) Plus, you and your mother should write the new code down and put the information in places where you will remember them. I like to put codes in my address book (a physical address book for people's names, street addresses, and phone numbers - very old school.) For a safe code, I have used the maker name of the safe as the "last name" and my first initial as the "first name". Example: Safewell, J. I have also made the code look like a telephone number. For example if it is a 6-digit code for the safe, I have made the code the first 6 digits, followed by zeros. Example: code is 987654, phone number in my address book: 987-654-0000 (USA phone number style.)
To open an electronic safe the first time, press the following numbers/letters on the electronic keypad -159B. (These numbers are preset. You should change the code as soon as possible after opening the safe to insure proper security). After you have entered the factory set code, you will need to turn the knob on the faceplate to open the door. You will have 5 seconds to turn the knob before the locking mechanism is reactivated. ENTERING YOUR SECURITY CODE To enter your own security code you will need to follow the steps listed below: 1. After opening the electronic safe (with the pre -set factory code of 159B) locate the small red button on the inside of the door near the hinge. 2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY. 3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter "B" on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
The original factory code
is 1-5-9 A (or B) to open the safe. There is usually an override key
for your safe in case you have lost your code.
Once the unit is open, you can reset the combination by pressing the red
button, the yellow light will come on. Input a new code 3-8 numbers
and then either the A or B button to finish the code.
Test your new code several times before locking.
If you don't have an over ride key, the first three digits of the serial number should be the key code.
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
