A typical answer for thisĀ·
1. Cut off power to the water heater at the panelĀ·
2. Check the water heater reset button- The water heater reset button is the red button situated on the water radiator itself (simply over the indoor regulator). Some water heater may have two reset catches one for each indoor regulator. To get to the reset catch, you may need to evacuate the metal plate covering the indoor regulator that is held set up by screws. You may likewise need to evacuate a rectangular bit of froth protection to see the reset catch(button).
3.DO NOT reset if safety features continuously trip.
For More Information You Can Visit: https://www.indiapropertyclinic.com/services/water-heater-install-repair
SOURCE: My hot water will not get hot at all. Model
Your upper thermostat on the hot water tank may be shorting out causing your breaker to trip. Remove the outer panel door on the side of the hot water tank and test for power going to the elements. Also check for water as the tank may be leaking and causing the short
Tom W must have been 'recommended answer' from past answers, and not live answer.
What did Tom's answer say?
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
If you need further help, Iām available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
