SOURCE: dmr-ex85 shows u81 code and is not functioning at
Physically unplug power from the unit for a minute or two.
Connect power cord to unit and Simultaneously Press & Hold
both the [STOP] and Channel UP [^] for 5 seconds. This will
force Eject the DVD tray. Remove any disc if present.
Cycle the power again if necessary and wait for the unit to
go through its self check cycle. If after several attempts, and
you continue to get this error, then your Ram drive may need
to be replaced.
SOURCE: Panasonic DMR-EX85 code error U81
You will need to call Panasonic customer support for more information on this problem. here is their contact information. Accessories; or make Customer Service and Literature requests by visiting our Web Site at: http://www.panasonic.com/support or, contact us via the web at: http://www.panasonic.com/contactinfo You may also contact us directly at: 1-800-211-PANA (7262), Monday-Friday 9 am-9 pm; Saturday-Sunday 10 am-7 pm, EST. For hearing or speech impaired TTY users, TTY : 1-877-833-8855 Accessory Purchases Purchase Parts, Accessories and Instruction Books online for all Panasonic Products by visiting our Web Site at: http://www.pasc.panasonic.com or, send your request by E-mail to: [email protected] You may also contact us directly at: 1-800-332-5368 (Phone) 1-800-237-9080 (Fax Only) (Monday ? Friday 9 am to 8 pm, EST.) Panasonic Services Company 20421 84th Avenue South, Kent, WA 98032 (We Accept Visa, MasterCard, Discover Card, American Express, and Personal Checks) I hope this helps you with your problem.
SOURCE: TENGO EL ERROR U81 EL
Tienes que comprobar que el condensador C1801 no se haya hinchado o tenga fugas. Si es así, comprueba tambiñen que el IC1801 no haya rebentado, usa una lupa. Cambia el condensador y el circuito integrado si ha rebentado. Normalmente con cambiar el condensador se soluciona el problema. El condensador está en la placa principal, justo debajo de la placa digital, la que tiene los cables planos que van a la unidad dvd. Espero que te sea de ayuda.
Check that C1801 is not leaky. If so, check if IC1801 has blown. If it has blown, it will also need to be replaced.
Usually it's only C1801 leaky, replace it and thats it.
You can find the capacitor on the main board, under the digital board that has ribbon cables going to the dvd drive.
Hope this helps.
Hard reset won't solve your problem.
Hope this helps.
This is a well known fault with Panasonic DVD players. If you search ebay you will find a repair kit containing 2 capacitors and an IC.https://www.ebay.co.uk/itm/U81-error-cod...
If you are able to solder you can do this yourself. Its a bit fiddly but I can confirm it works because I did it 2 years ago.
