Can you send me a video on it?
SOURCE: how do i replace the pcv valve on a 2000 explorer xlt v6 sohc?
On the passenger side of the intake manifold, coming off the bottom
about the center of the engine front to back, you'll feel a hose that
comes off a nipple. That hose makes a 90 degree bend and goes around to
the rear of the motor. Where that hose meets the Y-connector from the
other side of the intake you'll find the PCV valve. It's almost
impossible to see it with the hood installed, and even tougher to reach
it.
A good source of information for Ford Explorers can be found here
SOURCE: 02 Ford Explorer XLT 4x4 High light flashes and
I had same problem on my 2002 explorer. Its either the computer module, or the electric solenoid on the transfer case. In my case it was both. The computer module I had done twice in 14 months.
SOURCE: 1996 Ford Explorer XLT abs light comes on on
The ABS light is for the Anti-lock Braking System. The MIL will illuminate if there is a difference in wheel speed sensors signals to the PCM. So you might have a wheel speed sensor that is going out on you. Does the light come on at low speeds, or just higway speeds? You could take the vehicle to a local parts store and have them pull the codes for you and that will tell you which speed sensor is out of whack. Also road grime, dirt and gunk buildup can cause speed sensors to give false readings. Hope tihs helps you out.......
SOURCE: 2007 FORD EXPLORER XLT
need to set tires at correct pressure you can find a sticker on the inside of drivers door to tell you the correct pressure after you do that it sould reset the light after you drive
SOURCE: 1998 Ford Explorer: My mother lost both keys. I
the keys and locks are not only specific to a particular ford explorer year model but they are also specific to a particular model.
STARTER PROBLEMS
It
can be faulty starter or there is loose connection from battery to starter. The
starter assembly gets power from battery. Check voltages at starter wires and
see if you are getting 12 volts or not. If not then its no power issue due to
low battery volt or no connection between battery to starter.
To
solve these problem, I suggest you to refer these direct help links:-----
Click
the link below: ------
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
These
will help.
Thanks.
