SOURCE: penn fishing reels
For a Penn GTO 220, pls check this page an exploded view of the GTO220 that details parts and their placement. It is a PDF file and would need Abobe Acrobat Reader to view and print.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
SOURCE: Penn 113 senator
If ythere is a screw directly across from the crank, remove the screw and insert the crank from that side
SOURCE: No instructions for how to feed line onto Penn
put line through ur spreader on the multi[plier then tie a loop not cut off the little bit after tying knot then wind up slowly till it starts to get tight then speed up ur process till u are happy with the amount on ur reel
SOURCE: how do i reassemble a penn longbeach 68 saltwater
http://www.trails.com/how_39619_penn-long-beach-fishing-reel.html
Check out the above link
Testimonial: "good blowup picture- may help"
