If this happens with a "timed" cycle then it implies a power interruption to the motor. This could be as simple as the door switch or could be the timer (control) or any of the thermal switches, or other poor connection inside.
Door switch is a common failure. Try bypassing the door switch and see if problem goes away.
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At timesit may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
https://www.youtube.com/watch?v=QP1Z4OWjTuA
https://www.youtube.com/watch?v=pKLDrzXlzHM
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
SOURCE: Whirlpool Dryer Model # LE7680XSW1
David,
You have a pretty old dryer. Replacement is recommended because new dryers use less electricity and more than make up for the price with the savings on your electric bill.
However, if you still want to use this dryer, you will need to replace some internal switches. In order to guide you through that I recommend you use our premium service.
If you need to find a local repair service, please type your zip code into our repair service search engin located on our site.
Good luck,
CH
SOURCE: Dryer won't stay on.
tThe wiring diagram for your dryer is shown in the first image below. A
thermal fuse is normally in the circuit to the igniter on many gas
dryers. I recommend checking this fuse. On dryer model 11073032102, you
can access this fuse by _unplugging the dryer, shutting off the gas
supply,_ and removing the bottom front service panel as shown in the
second image below. On some Kenmore dryers, you have to remove the back
panel to access the thermal fuse. The thermal fuse is located on the
blower housing . The third image shows the location
and replacement procedure. To test the thermal fuse, remove at least
one wire (with the dryer still unplugged) and measure the resistance
across the leads of the fuse with a volt/ohm meter. You should measure
near zero ohms (continuity). If you measure infinite resistance (open),
then the thermal fuse is blown and will need to be replaced.NOTE: If
the thermal fuse is blown, check the venting for your dryer. Restricted
exhaust venting can cause the thermal fuse to blow.
thank You Huuum
Please remember to leave a solved rating before you sign off!
SOURCE: Dryer runs for a few minutes, then shuts off
thermo sensor inside is bad (are you sure ALL vents and pipes are clear?)
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
