SOURCE: Washer Power Requirements
Hello kgodsave,
You are not really going to run everything in the house while using your washing machine, isn't it? If your machine runs on 1 horse power (HP) motor (which is unlikely), thats already 746 watts. say you are running some little wattage appliances say total of 1,000 watts. Double that figure and you get 2kw. A 2kva to 3kva generator would be ideal...got plenty clearance for unexpected load.
SOURCE: amana front loading washer won't run after power outage. Panle does light up.
Possible that the program controller unit has failed if there is no display or power in the indication. You will need to remove panel to check on the fuse and if the new fuse fails it is possible there are error or hardware failure within the board.
Please remove and check the power panel for shorted drive, rectifier or capacitor, if not the panel must be replaced.
SOURCE: Why doesn't my GE Symphony 20kw generator turn off after the power comes back on?
The transfer switch could be bad, worn internally, a manual switch, or a semi-automatic transfer switch. Check the transfer switch part numbers and google them to find out exactly what kind they are. In some places fully automatic transfer switches are not permitted in a residential environment.
SOURCE: Where can I get an owners manual ?
PDF]10000W Generator
scene7.samsclub.com/is/content/.../GG10020-Eng%20manual-cpdf
Gentron/UPC will repair or replace, at Gentron/UPC's sole option, products or components ... Expendable parts or accessories supplied with the product which are..... FILLED WITH OIL OF A HIGH QUALITY SAE 10W-30 GRADE ENGINE OIL.
Gentron - 10000 Watt Gas Generator with Electric Start
www.samsclub.com > Sam's Club > Emergency Supplies
Sam's Club
Rating: 4.4 - ?330 reviews
Gentron 8,000W / 10,000W Portable Gas Powered Generator with Electric Start ...... 1 year parts and labor limited manufacturer's warranty; For issues not ...
Gentron Pro2 10000w Gas Generator (GG10020)
https://generatornow.com/gentron-gg10020-pro2-10000w-gas-powered-...
Gentron GG10020 Pro2 10000w Gas Powered Portable Generator with Electric ... It's a one year/1000 hr parts and labor warranty for our residential customers.
