First the machine woudnt wash the clothes then then door locked and I was unable to open it.
Now I can't not even get the power buttom to light up. The machine appears to be dead. It is not even two years old..
I need to get these clohes out of the machine before they are ruined.
There is a mechanical lock so you can't open it when running. make sure the switch is off but machine is plugged in. push the door in with a little bit of pressure and with the base of you hand give it a few gentle "thumps around the area of the opening handle it it likely stuck from you trying to open the door in the locked position. Hopefully that will knock it loose (I've seen it before you will probably here it click)
