SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
SOURCE: Washing Machine Fault Code
The recommendation to get a new motor may be overkill and a very expensive option. Also on this site I found an alternative solution which was to just replace the motor brushes. This we did and it fixed the problem, coasting us just £20.15, rather than the £199 quoted for a new motor!
A reasonably competent person needs to remove the motor, identify the brushes and remove - just involves two hex-head screws. When new the brushes will be around 2.5cm long. They need to be around 1 - 1.5cm long to work. Alternatively the spring(s) may be sticking, preventing the brushes from being pushed against the rotor.
When calling suppliers to enquire as to availability I needed not just the product description, but also the PNC and serial numbers (located inside the front door), as types of brushes have varied during the production period. However the outlet I went to still did not have the correct bush - housings were different. The chap serviing very kindly swapped new brushes into the existing housings - this is something you could do yourself if you cannot get the exact same ones - just a little fiddly.
Hope this helps!
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
SOURCE: My washing machine AEG lavamat
1) Hold in the Pre-wash & soaking buttons TOGETHER;
2) At the same time, turn the knob clockwise from the OFF position, to "Short Spin". All the LEDS light up.
3) turn the knob anti-clockwise to "energy saving"
4) Machine is reset and the door release clicks.
Switch your machine off and then back on again.
