I need to use a single solid grinding wheel. Still okay?
SOURCE: delta 23-880 bench grinder
You should be able to hold the grinding wheel with a pair of leather gloves on your hands and lossen the bolt. Look very carefully at the threads to make sure you are trying to lossen and not tighten. Some are left handed threads on bench grinders.
SOURCE: older black & decker bench grinder
Usually a new wire wheel comes with different size bushing just for the problem you are describing. Either that or take it back and get one specifically for your tool.
SOURCE: I need the instruction manual for using the Delta 23-700 grinder
You will be able to download one from the Dewalt Service Center.
Follow this link: and navigate to the instruction manual:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=43429&typeId=10220&documentId=29540
If that solves your problem, please take the time to rate this post.
Thanks!
SOURCE: Delta coffee maker: grinder not working
check the service section within your manual.
If you don´t have one, check here:
http://manualfox.com/
They can get you any Delta Coffee Maker manual. Just send them a request.
SOURCE: How do I replace the big gear on a makita 9557nb grinder
After taking the bearig box off the head, remove the retaining ring and wave washer on top of the gear. Some spindles can be tapped out of the gear with a hammer but be extremely careful not to mushroom the spindle head. It's best to take it off with a hydraulic press. There is a woodruff key in there so be careful not to loose that when you press the spindle out of the gear. The new gear should be pressed back on also.
