Can I adjust the glides?
SOURCE: f1
i can almost garentee you have a broken harness in the back of the machine and the piece of plastic is getting caught between the lid and tub. pull out the drawer there are two tabs in the bottom front corners push in and pull the drawer out futher you can now see behind the tub check the lid gasket is there a dimple if so you may be able to reform w/ you finger and some heat(hairdryer). there is an updated braket for your hoses that come w/ instructions. only other thing is the lid acuators which have also been updated.
SOURCE: bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
SOURCE: Remote slide door will not close or open all the way.
there is a cable of wires that lay in the track under the slider they break from normal use.. the harness it fairly easy to change.. when you open the door lok in the opening you will see the harness there in black plastic
SOURCE: driver's side door adjustment on a 2000 Chevy Blazer
check your door bushings in the door hinge these probably need replacing. if you can lift up on door and feel play they are wore out. common issue on these if not you can put a wood block betwwen bottom of door and body and push on top of door to bend it a little to close top tighter
SOURCE: desk drawer - slides open
my husband is having trouble installing a kitchen drawer slide--it keeps jumping off track--can anyone help??
