Water Heaters Logo
David Hoff Posted on Jun 08, 2019
I have a Rheem ProG50-38N water heater. It has turned off and I cannot relight it. The knob on top is supposed to turn to the "off" position, but it will not go into that position.
Don Walper
Level 1:
  • Contributor 36 Answers
  • Posted on Oct 07, 2019
Don Walper
Contributor
Level 1:
Answers
36
Questions
0
Helped
16259
Points
80
Thermocouple issue.
5 Related Answers
pvoisr
  • Posted on Jan 10, 2009
SOURCE: Rheem water heater with powerglow ignition wont re-light
I have fixed mine. The problem part is the Ignition Control module. It is made by Robert Shaw part # SP10758. I paid $93 plus shipping.
Works great now. A repairman wanted to sell me a gas valve for $488.
Watch out for these people.....
Donni Steen
  • 687 Answers
  • Posted on Mar 31, 2009
SOURCE: Rheem hot water heater, gas, pilot went out. Will
You can try cleaning the thermocouple with a piece of emory clothe or replace the thermocouple. Watch and see if the moisture continues, it just be condensation from humidity from the lack of heat under there. If the moisture continues, you may have an early leak.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Jun 15, 2009
SOURCE: can no light up a new Rheem 22V40FN water heater
Air in system. Make sure there is no sources of ignition and loosen the supply line at the heater and purge all air. Mske sure your source valve is open. then turn off yje heater after tightening the line. Let sit in off position for 15 minutes. Then turn therm knob to on slowly and then over to pilot, depress pilot button and hold a ffew seconds. Pilot should light. If so, hold for a few and then release and turn ti on position. Good Luck.
Anonymous
  • 244 Answers
  • Posted on Nov 01, 2009
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
tiltdeck
  • 48 Answers
  • Posted on Mar 14, 2011
SOURCE: Rheem NatGas hot water heater model 41V50,
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
2answers
Why won't control knob on water heater turn to off or pilot position so that I can relight
It usually needs to be pushed straight down, or into the valve body, if it is on the side.
2helpful
I have a 650 delta thermostatic gas combination control on a Rheem hot water heater that won't turn to to the proper pilot or off position to relight it. We have looked everywhere for trouble shootin
Jennifer, the instructions posted by Rheems on the heater are wrong. You must first rotate the dial clockwise, use force (in our our case) to get the pilot to its position. The folks at Rheems are nuts not to check their instructions before printing them and plastering them on their hot water tanks. Disgraceful, period.
Rheem 41v850 leaking at bolt on top
just turn off the gas valve for pilot light, turn off cold water to water tank. drain system. when refilling open cold water to fill tank, wait at least a 1/2 hour to 45 minutes then relight water heater. you should be fine!
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
Rheem 21V40-38 Gas - pilot light is on but when i turn knob to hot it does not do anything
Is the pilot knob turned to the "On" position? If the knob and temp dial are set in the correct position, you may have a recalled wtr htr which requires a retrofit "reset" button that needs to be installed. Call the manufacturer;s phone # that's printed on the side of the water heater and give them the model # and serial # and find out.
Douglas
1helpful
Im looking for the drain on a vanguard 3wa79 by rheem. i want to change the element but cant figure out how to drain the tank. i have looked all around the bottom of the tank and around the whole unit and...
The drain is a plastic valve, looks like a knob with a hose fitting coming out the middle of it. It should be about 1' above the bottom of the tank enclosure.
Be sure to turn the gas off before you drain the water and fill the tank before you relight it.
40 gal lp locked out at gas control valve. what are steps to unlocking valve?
Try turning the off pilot on knob to off and then turnign the temperature dial to the coldest position. then turn to pilot, relight and see if that works.
1helpful
Can no light up a new Rheem 22V40FN water heater
8helpful
2answers
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
