Hello, try to update the Firmware, search the Internet, on the Westinghouse website, place the model and look for firmware updates and copies in an empty USB memory, without any type of content
In most cases,this is the procedure to follow, after downloading, with the TV off or disconnected, you place it in the USB port of the TV, turn it on and wait for the cycle to end
Confirm on the Westinghouse page that this is the correct procedure
I hope you can solve the problem
Greetings Franco Dosil
Hola, prueba hacer la actualizaci?n del Firmware, buscas en Internet, en la pagina de Westinghouse, colocas el modelo y buscas actualizaci?n de Firmware y copias en una memoria USB vac?a, sin ning?n tipo de contenido
En la mayor?a de los casos, este es procedimiento a seguir, luego de descargar, con el televisor apagado o desconectado, lo colocas en el puerto USB del televisor, lo prendes y esperas que termine el ciclo
Confirma en la pagina de Westinghouse, que este sea el procedimiento correcto
Espero puedas solucionar el problema
Saludos Franco Dosil
Can you please send me link I couldn't find firmware update of the set . It's wd40fw2610 set no
Hello Aliza, I'm looking for the different sites of Westinghouse and until now I have not got anything, I'll keep looking, if I have any news I'll comment
Try to also search, in this way you can get faster
I hope the problem can be solved
Also I suggest you consult a specialized technical service of Westinghouse
Hola Aliza, estoy buscando por los distintos sitios de Westinghouse y hasta ahora no he conseguido nada, seguir? buscando, si tengo alguna novedad se la comentare
Trate por su parte tambi?n buscar, de esta manera se podr? conseguir mas r?pido
Espero que se pueda resolver el problema
Tambi?n le sugiero consulte a un servicio t?cnico especializado de Westinghouse
Thank you so much I'll definitely do that.
Aliza, it's the best decision
I hope you enjoy your Westinghouse TV soon
Muy bien Aliza, es la mejor decisi?n
Espero que disfrute pronto de su TV Westinghouse
SOURCE: Mitsubishi WS 65513 turns itself off
Probable four bad caps in DM module = 1000mf/25v
Common repair for qualified Mits tech...........T.
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
SOURCE: Westinghouse tv ltv46w1hd sound no picture
www.cfusion.com has the spare parts for that tv. it sounds like it is the mainboard. shouldn't be more than 150-200 to replace.
SOURCE: My 50 Viore dlp tv turns itself off after just a
HI, this may be a simple cooling issue. try inspecting the cooling fans that are located near the power sector. if these cooling devices are not operational, they will cause the power board to shut down periodically, due to heat build up.
If the fans are operational, this will confirm a weak and defective power power board.
SOURCE: Westinghouse SK 32H540S when i Turn on TV, get
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
