Electrical Supplies Logo
Ruben Parraz Posted on May 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do u rewire a 5250 watt generator on off switch
sherlywang
Level 3:
Master:
  • Electrical S... Master 428 Answers
  • Posted on Oct 16, 2019
sherlywang
Level 3:
Master:
Answers
428
Questions
0
Helped
198537
Points
1063
Do not you have a operation manual?
www.dieselgeneratortech.com
3 Related Answers
Anonymous
  • 1627 Answers
  • Posted on Jan 22, 2010
SOURCE: My 5250 watt Power Back generator will not start,
Have you check the engine oil level?If it is down on oil you won't get spark because of the oil level switch shutting the ignition down to protect it's self.
A
Anonymous
  • Posted on Oct 25, 2010
SOURCE: what type of oil do
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Anonymous
  • 16 Answers
  • Posted on Sep 03, 2012
SOURCE: I have a powerback 5250 watt generator that I
Not knowing the specifics of either my experience has been that if you use your gas water heater instead of electric 20 amps will generally get you buy, your AC probably only pulls 14 15 amp when starting up other facilities are very low amperage so try just not running both AC and Water Heater and Microwave at the same time.
Troy Bilt 3550 5250 Watts Generator model# 01924. How do I replace a Fuel Shut-Off Valve and grommet on it?
Question edited for clarity.
Question moved from Cars and Trucks to Generators.
Hi Joe
Good to see you. There is a picture of it here. I would put some Vaseline on the spigot and support the grommet at the back, push and turn at the same time.
This is a video here that may help
https://www.google.com/search?q=Troy+Bilt+3550+5250+Watts+Generator%2C+replace+fuel+valve
How do i rewire a off on switch to a 5250 watt subaro generator
If you need diesel generator set in future, maybe you can look at www.dieselgeneratortech.com, they have focused on high quality generator for more than 40 years.
What type fuel does a 5250 porter cable generator take
From p.10 of the manual
"Check fuel level, fill as required. Make sure generator is turned off and has been allowed time to cool down. Use clean, fresh, regular unleaded gasoline with a minimum of 87 octane. Do not mix oil with gasoline".
(taken from bottom of this webpage
http://www.cpoworkshop.com/porter-cable-bsi525-w-5-250-watt-electric-generator/pcbnbsi525-w,default,pd.html?cgid=porter-cable-delta-discontinued )
(Is this your exact model ?)
14.April.2014
THE VOLTAGE COMING FROM THE GENERATOR IS NOT RIGHT. iT WILL BLOW A LIGHT BULB INSTANTLY
Connect a voltage meter to the 115v plug and measure voltage. If too high, adjust governor spring tension to compensate. Your engine developes max horsepower at about 3600 rpm. At this speed the generator should be producting 115v at 60 cycles. Good holidays
1helpful
What type of oil do i take for a porter cable 5250 watt electric generator?
2helpful
2answers
My 5250 watt Power Back generator will not start, and their is no spark at the spark plug.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
