SOURCE: Delta 12 inch thickness planer blade change
Go to this link and at the bottom center of the page insert your model number. You will be able to download the manual for that machine.
Delta manual
If your question has been answered, or I fixed your problem, please take just a moment to rate this post...thanks!!
SOURCE: I have AP-12 ryobi planer and it needs new feed
go to tool parts direct and order one
Testimonial: "Thank you "
SOURCE: I need a manual for a shopsmith 12 inch planer
The Mark V?
Download the manuals from the link below.
www.shopsmith.com/ownersite/productmanuals.htm
Ken.
SOURCE: planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
SOURCE: how do you change the cutter bar bearings on a delta 12 inch planer
You are looking at a major disassembly to get at the cutter head bearings, everything is built around the cutter head. The motor drives the cutter head on one end of it and the cutter head drives the rollers at the other end. Most of the components have to be removed to get the cutter head and it's bearings out. You can go to www.ereplacementparts.com and do a search on your model number for a good breakdown of your planner and see what you need to remove to get at the cutter head and it's bearings.
