Refrigerators Logo
t
tom armstrong Posted on May 24, 2019
I have a dometic 2620 RV fridge and the ignitor stays on after it's lit
Bad control board
5 Related Answers
A
Anonymous
  • Posted on Jul 20, 2008
SOURCE: Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Anonymous
  • 999 Answers
  • Posted on Jul 07, 2009
SOURCE: my rv fridge will build up ice and freeze food too cold
The thermister for the temp control is a likely culprit. Eric
Anonymous
  • 9 Answers
  • Posted on Jul 26, 2009
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Anonymous
  • 15 Answers
  • Posted on Jan 29, 2010
SOURCE: norcold refrigerator burner will not stay lit
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jun 03, 2010
SOURCE: my dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
I have a Dometic RM 2620 fridge, that won't cool. A squirrel got into wiring, I have taken care of wiring but will not work on gas or AC. Spark igniter will no spark either. Any ideas?
Since I don't know what does work I am kind of shooting in the dark.
Does the ac heater get hot ?
The spark ignitor is part of the control board. But won't work?
I assume that you have a user manual but I am including a link to download one.
https://www.dometic.com/f6e8a773-69f5-4624-9b35-54e8801da7af.fodoc
Note that there are three fuses. B (12V control) and C (120V Heater) on the control board and a thermofuse L located on the stack.
If L is good and everything else is good there should be 12VDC on J1 and at Fuse B
Dometic RV fridge will not stay on while traveling
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Top Dometic Refrigerators Experts
Jay Finke
Jay Finke
Virgil Watts
Mike Cairns
Mike Cairns
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
