SOURCE: th8000 does not match another thermometer inside home
Is the thermostat mounted near a lamp or other heat source?
Is the wall warm from ducts in the wall or a refrigerator on the other side?
The thermostats are usually pretty accurate. Most times I find some other influence on the thermostat causes the problem.
The Honeywell 8000 series also has a feature accessed through the installer setup menu, that will allow the temp display to be changed + or - 8 or 9 degrees.
Check the manual or Honeywell's website for a .pdf if you need it.
Hope this helps.
Matt
SOURCE: Kenmore Deep Chest Freezer
Correct temperature for residential freezer for food is zero degrees Fahrenheit
SOURCE: 99 grand prix, Ac problems, problem with digital thermometer
JUST A BIT OF INFO WHEN YOU CALL THE PARTS STORE, THE PART YOU WILL ASK FOR IS CALLED THE AMBIENT CLIMATE CONTROL SENSOR. THEY WILL NEED TO KNOW THAT OR THEY WILL TRY AND SELL YOU A BUNCH OF PARTS YOU DONT NEED.
SOURCE: freezer and refrigerator run about 8 to 10 degrees
check freezer coil for ice, then defrost timer and then fan and switch fan
SOURCE: The thermometer that reads the outside temperature
its not in the engine area, its nearer toward the bumber area, and replace the sensor
