SOURCE: doesn´t charge
HY I HAD THE SAME PROBLEM WITH MPX 220. I'WE TRIED TO RESET IT BUT NOTHING , AND THEN I TOOK IT TO THE SERVICE SHOP AND IT SEEMS THAT THE PART OF THE PROCCESOR THAT HANDLES THE CHARGE IS DEAD . THEY RECOMENDED ME TO CHANGE THE PROCESOR . BUY , A MULTIPHONE RECHARGER . TAKE OUT THE BATTERY AND RECHARGE IT . BUY A SECOND BATERY . THAT'S WHAT I DID . BYE
SOURCE: please i don't know what wrong wit LCD monitor
Could be a bad inverter board or LCD backlight. Please refer to the following article for more details:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
