Hello, Richard -
1. I re-categorized your question from the Fixya category for Televisions, where it had initially landed.
2. I found warranty information about the Serta reversible heated throw from online sellers' posted information. Apparently, the throws come with a 1 year manufacturer's warranty.
3. I was unable to find a user's manual / user instructions for any variety of Serta reversible heated throws. I had hoped a user's manual would include Troubleshooting solutions and / or information regarding the manufacturer's warranty.
If you have printed instructions for the heated throw, I suggest you double check the instructions regarding Troubleshooting as well as contacting Serta Customer Service regarding the warranty for your throw.
4. This is the toll free number to call Serta Customer Service:
888-557-3782
Monday - Friday 9 am - 5 pm,Eastern Time
Best wishes.
SOURCE: Samsung 46 DLP buzzing noise dark picture flashing lamp did not turn off unpluged from wall outlet)
Thanks for your solution. This is a problem with color wheel. I could not fix it by myself, so my friend will try to fix it next week.
SOURCE: Room AC, reverse cycle..heat does not work.
if it is a Heat pump style the rev valve is in the Freon lines you will have to pull the unit out into the room out of it's sleeve which will stay in the wall ....it rev the flow of refrigerant is it cooling ok?? there is a solenoid on that valve that may be bad i would check that first you will have to look to see if it is energized in the heat or cool mode first to make sure it is switching it should look like a sideways tube with 3 outlets on one side and 1 inlet on the top and the solenoid coil as well with 2 wires going to it let me know what you find out ...1 Note the unit may have electric heat and the element maybe out you will have to pull to check
SOURCE: Acer aspire 4930 wont turn on
If the power LED on the Notebook is blinking but not turning ON then the issue is related to the power supply unit and service is required.
SOURCE: lamp and power flashing amber
The problem is the lamp driver, it can be repalced by dell for $250 plus parts. The specific problem is a capacitor on the driver board, if you know someone who can work on electronics have them replace the 3300u 10v capacitor on the lamp driver board. Usually the capacitor will be slightly bulged on the top (not flat) indicating it needs replacing. Otherwise look for a electronics repair shop in your area and set them in the right direction. Hope that helps.
SOURCE: I have a Marantz SR5500 and the unit will not stay powered on.
I have this problem. it is caused by an o/c mains transformer primary winding. the clicking and flashing light is the stanbyy circuit trying to switch the power on to the main (large) transformer when it gets no voltage out it switches back off
