SOURCE: HP 6210
Here is the link to all the support options for your printer including user manual and troubleshooting if you need it; http://h10025.www1.hp.com/ewfrf/wc/product?product=421991&lc=en&cc=uk&dlc=en&lang=en&cc=uk first follow this troubleshooting procedure if you have a windows pc connected; http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00093466&lc=en&cc=uk&dlc=en&product=421991&rule=36216&lang=en and this one for Mac; http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00108051&lc=en&cc=uk&dlc=en&product=421991&rule=36216&lang=en Hopefully this will resolve the issue, especially the third item about turning off the paper type sensor. any help you need with any of the procedures, please ask again. If this doesn't work, then; Make sure your drivers are up to date and not corrupted - download new drivers from; http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=uk&dlc=en&product=421991&rule=36216&lang=en& see if you can borrow another printer from someone (doesn't have to be the same, but that would be best), install it and then see if you get the same problem, confirming if the data transfer from the pc is or is not the problem. If the other printer works fine, then the next thing to suspect would be the power supply - try plugging into a different power socket, and try and get hold of a new power adaptor and see if that works. Replace any connecting cables to the pc with new good ones, just in case that is the problem. Hope this helps, if the machine prints at all then it should be fixable :)
SOURCE: HP Photosmart 7760 Slooooow print
I had the same problem and it turned out to be a faulty tricolor printer cartridge. I changed my cartridge and it worked normally. I hope this helps!
SOURCE: HP PSC 2410 very slow printing issue
It is a cartridge problem. Solution for my hp 3645 (I have the same story as bb18, but different printer) was to remove color cartridge!
The printer is fast now, of course it does not print in color :) (I`m waiting for a new color cartridge) Good luck,
Marcin
SOURCE: laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
SOURCE: HP Laserjet 1200 prints pdf documents slow
I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
CHEERS AND VISIT //dentaltourism.rs
