Yes it is. It's a cheep fix. The fans are on ebay. If you have the manual for the TV. Look in the specs for the TV and locate the fan. You will see the voltage and rpm of the motor. Most likely it will be a 12v dc fan. It has two to four screws holding the fan. And a small plug. I hope this helps you in some way. THE CB SHOP OF COLEBROOK NH. Via Facebook.
SOURCE: Loud buzzing noise
Yes,it sounds like the color wheel motor is going,and yes it satais on untill lamp cools down
SOURCE: mitsubishi ws-55613 55in.
Four bad capacitors in DM module = common repair for
qualified Mits tech.......................T.
SOURCE: WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
SOURCE: Air conditioning fan makes loud noise the faster you ru it.
Concerning your broken vent -- this can be caused by a broken linkage or a malfunctioning servo motor as well. these vent have air ducts the sway back and forth to adjust the dual air flow function. if the servo o linkages are malfunctioning or not connected for some reason, it will not allow total control of the air flow and temperature range. Now, if you have a combination of a flow error and temperature error as well, thai can be caused by a combination of the two.
In this case, you will need to inspect the linkages as well as the servo motor function as well. in addition, i would test the air temp sensors for there operational value. they control the temp when you adjust the coll or hot function.
Concerning the Loud noise coming from the blower fan---
This issue can be caused by a misalignment within the blower housing or, it can also be caused by some minor damage within the motor itself, causing it to rotate in a erratic manner, in return, forcing it to rub against the housing itself. the best solution here is to extract this blower fan housing and inspect for lose fan propeller and motor stability. replace parts accordingly.
PLease rate and have a great day:)
SOURCE: When you turn the TV on it stops at the blue
There is a software update that is available for some Mitsubishi dlp models. The wd-65c9 is one of them. When I experienced your problem, I went to the website, downloaded the update, and installed it on my tv and boom, its fixed. It's super easy, free, and takes a few minutes.
