SOURCE: Halo Grandfather Clock won't chime hour
In my eyes there are two kinds, ones that are a real grandfather clock that runs on gravity using a series of weights and gears with different counterweights for chimes and running the clock itself, and there are the show pieces that look like a grandfather clock but run on newer tech and electronics. If a real one then would try first pulling the weights to the top. They are usually shaped into a pinecone or something. If weight is at bottom them have to pull corresponding chain with weight till the weight is at the top of case. As "time" goes by the weights lower. You should have different counterweights for the clock, chimes, dancing figures and whatever else it may have. All the weights move at different "speeds" so you have to keep an eye on them to make sure it keeps correct time. I would recommend consulting the manufacturer if possible. There are so many kinds out there is really hard to tell by such a short video.
SOURCE: Gazo Rancho Santa Fe Grandfather Clock won't chim
Check the wires in the back.some times the get corrodes.
SOURCE: I have a Seth Thomas
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
SOURCE: how do i set the chimes on an ansonia 8 day west minister chiming clock
The next time it gongs simply open the door and take the dial nut off and remove the hands. Now just simply put the hands back on matching the number of times it gonged.
UsedClockParts.com
SOURCE: Howard Miller grandfather clock keeps good time but chimes are off and five hours late
If you need to ask how to fix it, it probably means you shouldn't be tinkering with it.
You have something that represents a fair chunk of money and it would be wise to consult an experienced horologist about your problem or perhaps consult the manufacturer.
The cure might be as simple as removing the hands and putting them back to coincide with the chimes but it is presumably a fault that developed over time. I doubt the hands moved their relative positions by themselves but rather something inside happened.
Owning a mechanical pendulum clock is a hobby that requires some basic knowledge about how it works and how to care for it. The hands should never be turned backwards, for instance. Changing the time for daylight saving means either stopping the pendulum for an hour or advancing it by an hour and pausing at each quarter to allow the chimes to sound fully. Any mistakes will mean winding on many hours or stopping the clock and waiting.
