SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
SOURCE: SAMSUNG RS20CCMS
Defrost by turning off for 48 hours and the unit will work ok (for a while)
Its a design fault common to many Samsung Side By Sides
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
SOURCE: samsung SRS583HDP fridge not cooling. Side by side
Most likely the thermostat in the fridge, especially if it read 5 degrees until you reset it. Possibly the compressor in the fridge side as this fridge has twin cooling, or the circulating fan in the back of the fridge is frozen, which is a common problem as well.
Easiest things to try is to see if the fan is frozen and check if the fridge cooling is actually working. Turn off the fridge, remove the shelves, remove the 4 screws that hold in the bottom cover and the 2 screws that hold the water tank in. Cover should then come out a few inches. Reach behind and unplug the 2 plugs and pull out the cover. If the cover doesnt come out easily it may be glued to the back of the fridge by ice. Leave for a couple of hours and gently prize it off. Check for ice around the fan and that the fan spins freely. You could try sitting the cover inside the fridge, plug it in turn it back on for a few minutes (be careful) and then open the door and quickly look / listen to see if the fan is still spinning (it stops when you open the door). Leave the fridge off for a while until the ice disappears off the coils. Turn back on for half an hour. The coils should be icy again. Anything else call Samsung. If the deal in your country is the same as mine the fridge has a 2 year warranty but in the fine print the sealed compressor unit has five years on parts only. You could get the unit replaced for labour costs only. Check your warranty card.
SOURCE: Hi I have pressed the vacation
The settings will reset to a lower settting as the fridge/freezer will not be disturbed . So wait for the fridge to run and shut down and it will continue to run in this low mode to save power but to keep the food in prime condition. The fridge alone will not be shut down.
