SOURCE: Konica Bizhub's Trays
You will need to go to the printers folder under Start, settings, & select the C252, right click on it, select properties & go to the 'Option' tab.
In here input the C252's IP address into the 'printer name or IP address' field and select gather option information.
Once done you will need to apply the settings and ok.
If you dont know the IP address you can get it by going into Utility, user settings, print reports, config page.
You should now be able to select the correct trays without errors.
Hope this Helps.
SOURCE: Canon MF8180C "In Use/Memory" won't clear
http://support-au.canon.com.au/contents/AU/EN/8000123601.html
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
SOURCE: need written instructions on how to reset Ip code Konica bizhub C451
there are two ways you can rea\set the ip address you can press utility counter administrator password is 12345678 the go to network ip address and you can chane it there if you know the ip address you can browse to the machine and log in as administrator and go to network and reset there
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
