Question about Cameras
I have kodakeasyshare camera,put wrong charger on it it flashed,but now the lens won't retrack is it fried
  • 42 Answers
Yes, it is history.
Posted on May 12, 2019
SOURCE:
t00nz
  • 4738 Answers
SOURCE: lens wont retrack/ camera wont turn on...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jun 15, 2009
BillB-SA
  • 2761 Answers
SOURCE: KODAK Z1275- NEW IN DEC. CAMERA WILL NOT TURN ON
This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. If charging/replacing the batteries does not clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Posted on Aug 16, 2009
BillB-SA
  • 2761 Answers
SOURCE: Camera will not stay on, lens retracks.
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean both ends of the batteries, place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time to replace the batteries, or the camera may have a problem that requires professional repair.
Posted on Jan 04, 2010
  • 11967 Answers
SOURCE: zoom button stuck and now camera lens will not
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 19, 2010
  • 1382 Answers
SOURCE: getting an error code E 45
Error 45 in your camera clearly indicates it is related to a lens issue. Something has caused the lens to jam or stop working. When it does you get the E45 error you have to update the firmware and the error should go away.
Thank you !!
Posted on May 24, 2010
The lens of my sony camera will NOT retracked. What can I do, I love this camera.
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
Dec 18, 2010 | Sony Cyber-shot W290 Digital Camera
Getting an error code E 45
Thank you !!
May 23, 2010 | Kodak EasyShare CX7430 Digital Camera
The zoom lens don't retrack Display don't
Charlene, It seems that there some dust that has entered between the lens housing and the camera body. To remove it you must use the vacuum cleaner to pull out the dust from this place. And keep switching on and off the camera so that it tries to move the lens inwards/outwards. If this does not work then the movement mechanism of the lens may have got stuck and would require more serious efforts for which you may or may not have to tools and knowledge.
Nov 02, 2009 | Vivitar ViviCam 8400 Digital Camera
THE TEL PHOTO LENS WON'T RETRACKED
That happened to me. Camera is a few years old so the warantee was long gone, so I actually took it apart and cleaned inside it with electronic cleaner.
If you still have a warantee you could call customer service and speak to a technician.
If you know how to put things back together easily, you can try it. You could probably use Air in a Can to spray around the lense.
I sure hope this helps!
Oct 23, 2009 | Cameras
Samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
Oct 20, 2009 | Cameras
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Not powering off
lights flashing like that usually means something is wrong in the shut-down procedure. my guess (and is quite common ) is that the lens doesnt retrack all the way hitting a clitched gear spline or something, maybe just weak motor,....as your retry it it settles in proper and tells the micro its ok now to shut down. good luck
Sep 01, 2007 | Sony Cyber-shot DSC-W35 Digital Camera
Cameras Logo
174 people viewed this question
Top Cameras Experts
Marvin
Marvin
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Camera Expert? Answer questions, earn points and help others
