SOURCE: WHEN I INSERT CARD, CAMERA SAID CAN NOT BE USED.
the 4800 is a older model that won't support a sdhc card-go back to 2gb or smaller and problem solved-don't waste money on high speed cards for a basic point and shoot camera
SOURCE: Sandisk 1.0 gb sd card get backup providation details
Try this link... you may want to try this software to recover your images...
http://www.cardrecovery.com/?rid=google&kid=cr0103
SOURCE: new nikon coolpix s570. sd card is not uploading
Use a good antivirus software to scan the SD card. Your SD card could be infected.
Hope this helped.
SOURCE: why won't my Nikon coolpix
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Another possibility- SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Finally, it may be that the card is not formatted. Most come pre-formatted, but there is a format function in the camera that you can try. Formatting deletes anything already on the card.
SOURCE: i have a sandisk sdhc
I would try to insert it in your PC and then format the card. Then reinsert in your camera and
see if that helps.
