Washing Machines Logo
j
janet billington Posted on May 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have AEG fli0661t3 and it says water safty message
Fernando Segovia
Level 2:
Novelist:
  • Expert 270 Answers
  • Posted on May 04, 2019
Fernando Segovia
Expert
Level 2:
Novelist:
Answers
270
Questions
Helped
64825
Points
442
Google AEG flio661te gives water safety message for answer.
Have AEG washing machine and says water safty message
google AEG washing machine gives safety massage.
Aeg washer has message water safty message
google AEG washing machine trouble shooting for answer.
I30 message on aeg favorit 50879 u
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
6helpful
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Message -spray arm blocked
Check water pump inside the machine for its full speed.If the speed is low check the capcitor and replace.
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
3helpful
AEG OKO-FAVORIT 50800
C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
If this happens often you have a leak somewhere. Time to cal the technician then.
2helpful
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Top AEG Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
