A valid point but unfortunately your machine is programmed to take both and will register this as a fault.
This is probably not what you wanted to hear but please dont shoot the messenger.
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Hello, This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry. Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
