SOURCE: Child Lock on or Flashing Energy Saver Dry
I suspect that the cycle "button" on the control panel is intermittent. Try using a different cycle - If you always use "short wash", try the "normal" cycle.
This worked for me. It will be too expensive to repair, so I am dishwasher shopping.
SOURCE: AEG Santos S83168KD1 - The
Hi there. Here are few tips on how to reset AEG refrigerators
Control Panel (water dispenser) I J N M O K L I. Yellow indicator lamp Lights up when the locking function has been activated. J. Button for carbonated water. - Used for the choice of carbonated water. - For the engagement and disengagement of the locking function. K. Button for ordinary water. - Used for the choice of ordinary water. - Switches the background lighting on and off. - Switches off the indicator lamp for water filter replacement. L. Yellow indicator lamp Lights up when the water filter must be changed. M. Water out-feed Activated when a glass or something similar is pressed upwards against the flap. N. Flap O. Lighting AEG/Electrolux 8183969-01/6 9 The functions of the water dispenser The locking function: The locking function is activated by the production plant. For temporary unlocking: Keep the button (J) pressed in for about three seconds until the yellow indicator lamp (I) goes out. The locking function is re-activated automatically after about three seconds. For permanent unlocking: Keep the buttons (J) and (K) pressed in at the same time for about three seconds. The button (J) or (K) lights up to indicate unlocking. To activate the locking function: Keep the buttons (J) and (K) pressed in at the same time for about three seconds. Activation is indicated by the yellow indicator lamp (I) lighting up.
Click the link i have provided to you for the service manula of your refrigerator. Scroll down and look at the right side then copy all document on the text box then paste it to microsoft word. Please click here for the manual.
SOURCE: self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
