S
SANNI Posted on Apr 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have delay while booting my bizhub 20 photocopier machine, how can i fixed it?
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Mar 22, 2020
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913072
Points
11959
How to fix black smudges all over paper in Bizhub c3110
The old toner collector is full so old toner is being deposited back onto the drum. You need to dump the old black toner reservoir out.
How do I fix trouble code c- 0204 on my bizhub C554e Photocopier machine?
Tray 2 feeder up/down abnormality.The paper feed tray 2 upper limit sensor is not blocked even after the lapse of a given period of time after the lifting motion has been started.Check the sensor and the sensor actuatos.
1helpful
Error c3452
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3helpful
6answers
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
2helpful
3answers
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
1helpful
Bizhub 162 autoshuts before photocopying
1-turn the machine off, 2-press the "STOP" button, 3-Turn the machine "ON" 4-keep the "STOP" button pressed. 5-wait until the main display shows. 6-release the "BUTTON"
Machine will not disturb you again
Best of Luck.......
1helpful
4answers
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
