SOURCE: no cooling in refrig, botton freezer forming too much ice
I had the exact same problem last month. After reading another article here, we opened up the freezer's back panel, melted/removed the ice and then replaced the DEFROST THERMOSTAT that we got at a local applicance parts house. It works great (actually better) now.
SOURCE: flat ice forms at the bottom of the freezer compartment
check your freezer door see if it (ajar) what you can do if you can unplug unit clar drain with hot water then get apiece of shave wire hook on the defrost heater and put in drain line 1/8 in the drain line put back wall back together and plug unit in
SOURCE: Kenmore refrig model 10671182101 water leaking in the interior
iced up drain , clean and defrost drain
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
SOURCE: model #GBS22HBPACC freezer is
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
