SOURCE: kitchenaid front loading washing machine
check your drain hose see if its too low lower than the tub or too far down in the drain as this will cause a siphon action
SOURCE: Sears Front Loading washing machine Model 45991 400
go to wwww.managemyhome.com and look for Search Product Manuals on the home page. Input Kenmore as brand and 45991 as model.
SOURCE: sounds like rocks in my front loading washing machine
did you try removingthe lower acess panel and checkin g the drain pump for possible obstruction??
SOURCE: LG front load washing machine - need to replace drain hose
It's jusy one clip go in from the bottom
SOURCE: Why does my front loading washing machine smell ba...
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Normal
0
false
false
false
font-size:10.0pt;
The filter on your pump is probably clogged with lint and
stuff. You have to remove the bottom front panel, 3 torx screws underneath. The
panel will drop and come off. Drain off the excess water from the hose you
see. The white filter cover is right in front.
Get yourself a bunch of towels or a good big plastic bag to collect water.
Unscrew the filter cover and twist the filter out. Clean out all the stuff and
put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be
stuck around the inside tub of your washer. Try this product, it works great on
all front loaders. Use hot water with the Affresh pellet with no clothes and
run the machine through a cycle. Also
helps with any stagnant water smells. Have you cleaned out your pump
lately. Put the pellet inside the
machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
