Televison & Video Logo
A
ANDREW MENA Posted on Apr 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG TV, model number 55LF6090-UB, repair advice. All three HDMI ports have separated from the main board. Need assistance identifying a correct replacement board.
There is an orange sticker near the middle of the board, with the numbers: 5NEBT000-01GR, EBT63746906 and RU5NL1A13Y. There is also a number stamped along the edge of the board: EAX65610207(1.1). Do all numbers need to match up exactly on the replacement board, or are there some boards interchangeable and compatible with my TV? Thank you so much for your assistance!
Raj Patel
Level 3:
Genius:
  • Master 1,042 Answers
  • Posted on Apr 26, 2019
Raj Patel
Master
Level 3:
Genius:
Answers
1042
Questions
Helped
270586
Points
3723
See main boards at this link: https://www.shopjimmy.com/lg/55lf6090-ub
One of them should match yours.
5 Related Answers
Anonymous
  • 1077 Answers
  • Posted on Apr 17, 2009
SOURCE: replace main board on LG 42LC7D-UB
Try this place, http://www.shopjimmy.com/catalogsearch/result/index/?q=42lc7d-ub&p=2
I the best place I know of to get parts at a good price.
There are a couple of boards that have different part numbers. You'll have to match the part# with yours. It maybe out of stock, but click on it. Then click on "find other products with this part number". Then all the main boards show up with that part number. A couple of them should be should be in stock.
Anonymous
  • 85 Answers
  • Posted on Sep 26, 2008
SOURCE: TV repair person told me
Even if you buy the parts you may get sticker shock!!! Why did it need a power supply and another board. Will your set come on? I may be able to give you part numbers but you need to be specific about which other board you think you need such as X Y signal board or power supply Some single circuit boards for some sets are as high as 600 bucks hope not for you
Anonymous
  • 8 Answers
  • Posted on Mar 13, 2009
not sure what you're referring to as a "main board", but heres the LCD Control Board for the TV
http://cgi.ebay.com/LG-42LC7D-UB-LCD-CONTROL-BOARD-6870C-0119A_W0QQitemZ150277759127QQcmdZViewItem
Anonymous
  • 1244 Answers
  • Posted on Jan 14, 2010
SOURCE: Serial number of ASUS motherboard
its imprinted in the board itself in SMALL letters need a magnifying glass and a flashlight to see then there either near the center or the outside edge
Anonymous
  • 691 Answers
  • Posted on Feb 17, 2011
SOURCE: I have a non-functional Sharp LC-32D62U (32") TV.
It would be possible if you can go into service menu and write all settings and implement with the new board by going back in and changing what you wrote down.
1helpful
2answers
My TV is a LG 47LN5700-UH I had a lightning strike near the house. Afterward TV would start but not boot completely. Now it won't start at all. Cable box also got fried at the same time.
The led driver AND the T-con board are bad. If you could see a picture with the flashlight then the T-con board would be good. It is not. The led driver can be on the main board or the power supply board. You can get these parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
2answers
LG 60PN6500-UA broken HDMI port and clicks when power on
It will most likely go away when you fix the board. I suspect there is a logic system in there looking for that port and is not finding it.
1helpful
My LG 55LV5400 Tv went of and will not come back on?How to fix this problem
LG 55LV5400-UB has a well known problem with the main board resulting in the symptom you describe or in loss of HDMI inputs or loss of sound.
it has to do with the main processor and some people recommend baking in an oven to help cure it.
We do not. There are many reasons why this is wrong, but the truth is it *could* give a short term success; it is almost certain to lead to long term problem and we have pictures and videos of boards sent to us after such attempts - usually already warped beyond repair.
Simply put, I'd say there is 99% chance you need your main board serviced or replaced.
here are two links to help with each option:
Repair:
http://www.coppelltvrepair.com/p/1632/ebt61521404-61521404-main-board-repair-service-from-lg-55lv5400-ubausylhr-led-tv
Replacement:
http://www.coppelltvrepair.com/p/1634/lg-55lv5400-ub-main-board-ebt61521404-61521404-serviced-tested-50-credit-for-old-dud
WHICH BOARD DO I REPLACE ON MY LG TV IT SHORTED OUT ,NOW POWER IS COMING OUT CABLE IN PORT... DVD PLAYER WORKS IN HDMI PORT 3 SOUND AND PICTURE IS FINE ALSO WERE CAN I GET BOARDS.....
Not sure how you could have power coming out the cable in terminal, Ive repaired thousands of sets and have never seen that...how much voltage do you have there?
HDMI ports won't work
you will need the MAIN PCB & can find your part number at the following web site, you will need your complete model/serial number to isolate the right board for your TV.
http://www.shopjimmy.com/tvs/tv-main-boards?tv_brands_select=Lg&tv_models=Lg+32LG30-UD
HDMI ports not working on a LG 471V5500 tv after lighting storm
If your other inputs are working, then you will need a Main pcb.
Try the following web site, but you will need the complete mode# for the correct pcb for your unit:
http://www.shopjimmy.com/tvs/tv-main-boards?tv_brands_select=Lg&tv_models=Lg+47LV5500-UA
1helpful
2answers
HDMI PORTS DONT WORK
You will need to replace the main video logic board, its part number is either EBU60852909 or EBU60852911. These two board are direct replacement parts. There are several boards available on Ebay such as this one: http://www.ebay.com/itm/LG-46LD550-UB-Main-BPR-Total-Assembly-EBU60852909-subs-to-EBU60852911-/150895037335?pt=US_TV_Boards_Parts_Components&hash=item23220b8b97
1helpful
46" Samsung LNT4661FX /XAA LCD TV volume problem.
If sound on one HDMI and not the others---all three should go to the same board--either something is not connected inside or the replacement board is the issue---Samsung is known for making boards with the same part number on them that from week to week have different features or do not have certain features.
Try to trace where the working input goes and if to same board as other two you know what to suspect.
3answers
No picture, only sound on LG 47LV5500: how do I get picture back?
Definitely odd for sound to come through and not sound, especially via an HDMI connection.
I would contact LG for support, your TV could be defective.
Good luck
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
