SOURCE: I need the code for a sanyo tv with one for all big easy remote
0154, 0159 these are the only two I can find. Hope it helps.
SOURCE: Big Easy programming
TV
Toshiba
0154 0156 0060 1256PROGRAMMING
TV/VCR COMBO CONTROL
Perform the following instructions to
control a TV/VCR Combo:
1. Turn on the TV/VCR Combo and
insert a video cassette.
NOTE: Please read steps 2-4 completely
before proceeding.Highlight or write down
the codes and device you wish to program
before moving on to step 2.
2. On the remote control,press VCR/DVD.
Press and hold SET until the LED
blinks twice, then release SET.
3. Use the Setup Codes For TV/VCR
Combos (on the back side) to locate
the brand name and then enter the
first four-digit code for your device.
If performed correctly, the LED will
blink twice.
NOTE: If the LED did not blink twice, then
repeat steps 2 through 3 and try entering
the same code again.
4. Aim the remote control at the device
and press POWER once. It should turn
off. If the device does not respond,
repeat steps 2-3, trying each code for
your brand until you find one that
works. If it still does not work, try
Searching For Your Code.
NOTE: If the device does not have a
POWER key, press the (PLAY) key.
hope that helps
SOURCE: Need 4 digit code for One for all remote
Try
0154 0156 0060 1256
You can get a manual from
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc4330-manual.zip&area=other
SOURCE: I have a one for
needs the codes for a one for all big esay remote urc-3300b03
an emerson tv
