This is a small refrigerator for my office. I plugged it up and left it on all night, came in this morning and still NOTHING, no fans on, not cold...Can someone explain what I should do without buying a new one?
SOURCE: cubic feet?
Most refrigerator models with two digits, the rest letters, the digits stand for the cubic foot capacity of the refrigerator. In you case, 23 cubic foot model.
SOURCE: Kenmore refrigerator and unknown capacity specs
It should be 25 cubic ft. It is usally the first few numbers in the model number.
Phil
SOURCE: What is Cubic Ft Capacity of Washer?
It's in the model number, and it's 4.4 cft. Which is one of the largest capacity washers available.
SOURCE: What size fuse to use in a Black And Decker NuCool
3 amp but if that is blown theres 2 diodes near it the may be bad . i had the same problem
SOURCE: I have a nucool mini refrigerator 2.8 cu. ft. I
Dear Friend!
Without knowing exact fault, replacing modules will not solve the problem. Check compressor is working, If so, keep your arm on condenser coil or discharge line. If you feel hot, it's working If not no gas. If working, you will get slight whistling sound on initial stage in freezer, as gas flows. If no soul\nd like this, gas chocked. You have replace filter drier and flush out system and recharge gas. My humble advise to call repairman to check completely. Thanks.
