24" beaumark self-clean STOVE-- can.t get door to close
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
SOURCE: self cleaning mechanism is locked with door open will not shut off
hold in on door light switch hit cancel
SOURCE: beaumark stove
The bottom element quit working and whats up with that!!!It is not burnt out we checked for that
SOURCE: GE profile spectra gas stove displays 'locked
You might try to reset the unit by unplugging it. Plug it back in, reset the clock & try it again. Hope that helps.
SOURCE: accidentally pushed self clean on Kenmore stove
Hello there:
on these units they have a self resetting device that you will need to activatethis is done by unplugging the oven for at least one hour then plugging it back in and wait for 5 min then press the normal cancel buton or you might even hear a click sound then you will be allowed to unlock it ok and close the door hope this helps you out please rate this solution it helps get better results for our customers like you
best regards mike
