SOURCE: RCA tv only in black and white?
The route through the circuits in the TV from the various sources all lead to the final video amplifiers for red green and blue. Somewhere along the route is a circuit called a colour switch. This allows colour if the signal is strong enough, otherwise it only allows black and white. This fault suggests a weak video chip which is the one just before the switch circuit. the fault could also be a faulty coupling capacitor to or from this chip, or a low power supply voltage. Check for dry soldered joints around this circiut. Please note if resoldering on new televisions that they may have non leaded solder which requires about 50 degrees centigrade hotter iron.
SOURCE: black and white playback on television screne
Select the correct color system in your tv. probably the system which was selected in your tv did not match that of your video cam. good luck!
SOURCE: Black and White instead of color
Assuming you are using the VS-2 with your system. I have experienced the same problem when I fiddle with equipment. Each time it is due to the S-video plug from the VS-2 cable becoming loose or detached. Make sure every cord is re-inserted into the back of the LS 38.
SOURCE: Wii is in black and white rather than color on Samsung?
change the wii-tv connecter. please vote.
SOURCE: Components are in black and white instead of color
Wrong connection. Hook up the component output from DVD player or Wii to TV component input using component cable(red, green and blue plug)
