Dryers Logo
Michel Santaquilani Posted on Apr 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The cord receptacle on my Dewalt 618 router cracked. I received the replacement part, but now I have to disconnect the old receptacle from the wires. How do I do this?
barrybam
Level 2:
Sergeant:
  • Expert 208 Answers
  • Posted on Apr 21, 2019
barrybam
Expert
Level 2:
Sergeant:
Answers
208
Questions
0
Helped
76760
Points
651
Undo the main housing to access the connections. Note each screw's placement as some may be smaller than others.
5 Related Answers
Anonymous
  • Posted on May 27, 2009
SOURCE: Replacing a power cord for a Dewalt electric drill
some of the dewalt drill switches have a one way trap (like) for the wire. you push the wire in and the harder you pull it gets tight on its self. your wires go in the bottom of the trigger look right on top of each wire there is a small **** (no bigger then 3/16) for a flat head screw drive. In the **** you will see a small lever, it needs to be turned at the same time pull. It will help to have a friend.
Anonymous
  • 332 Answers
  • Posted on Mar 07, 2010
SOURCE: I have two dewalt 1/2 electric drills and the
You will need to lay the drill on a bench then remove all the screws that hold the two halves of the case together, carefully pull the case apart to expose the wire connections
Anonymous
  • 351 Answers
  • Posted on May 04, 2010
SOURCE: gfci trips
Yes , your approach to troubleshooting is a sane one .. start at one end and disconnect things untill the fault goes away. There may be a loose wire, one rubbed by a mounting screw, or a broken wire that is grounding the circuit. all these things should be looking for as you take each receptacle out and check it ..
Anonymous
  • 8 Answers
  • Posted on Oct 29, 2011
SOURCE: cord replacement
it goes into the hole on the underside of the switch
dannydoesita
  • 778 Answers
  • Posted on Feb 28, 2015
SOURCE: where does the green wire connect from the power cord on a dewalt dw 236 drill
Your not clear at which end your working. If you are connecting green wire inside drill case , it will go to body of drill. If you are replacing a cable plug, it will go to the round pin connection on the inside of the plug. GOOD LUCK FRIEND.
I I
o Round pin is ground plug.
Testimonial: "thanks man this was very helpful"
1helpful
Need to replace broken dewalt 618 magnet ring.
you have to take four screws out from top of router. i used a large flat head screwdriver but actually the screw has a weird head like a cross between flat head and star. anyway once you remove cover you should see the bearing in the center. you need to use a bearing/gear puller to remove it. the magnetic ring lays just beneath the bearing. if its still there. mine was in pieces. clean out the mess and then the magnetic ring slides on flat side down. then LIGHTLY tap the bearing back into place. i used a small hammer. there didn't seem to be any lubrication in there so i didn't add any.
Cord got cut on my dewalt screwgun. dont know how to rewire to the trigger
Have you removed the old cord yet, if not make a crib sheet showing where the wires go. If the wires push into the switch use a staple and bend one of the long ends and push into hole and when pushing gently pull the cord wire out. Let me know if you need any other help
I have two dewalt 1/2 electric drills and the extension cords are cracked. how can i replace the extension cords?
I am changing the 4 wire on my 2 yr old maytag dryer to a 3 wire to fit the recptical in my new house. Other then the 2 hots and 1 neutral connection, my dryer also has a white ground wire off to the side,...
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
Feb 19, 2010 • Dryers
2helpful
3 wire to 4 wir
2answers
How to hook up a 4 wire plug to a Maytag clothes dryer model LDE8824ACM with 3 wire connecters.
Feb 09, 2010 • Dryers
1helpful
Need to replace existing three wire plug with new four wire plug. there are only three terminals to connect to. what do i do?
Based on your description....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
Feb 08, 2010 • Dryers
1helpful
2answers
Need to change from 3 prong cord to
disconnect the green or brass ground strap from the terminal block to the body then wire the new plugs three colors the same as the old then connect the green from the plug strait to the body. on a 3 wire the dryer is grounded through the neutral, on a 4 wire the ground goes to the body.
Dec 02, 2009 • Dryers
1helpful
How to open the case in order to replace the bearings
This is a serious disassembly and re-assembly.
Not only do you need to remove the yellow plastic cover end, but also disassemble the collet end. Depending on which version 618 you have it may have screws on the collet end or just a large nut. Sometimes you can't see the screws because they are plugged or covered with wood dust. The bearing is press-fit on the shaft on at least one end and requires an arbor press and special pressing sleeve. So you can only get so far on one of the 618 models then you have to use the arbor press to finish disassembly. The outside of the bearing sits in a very very close fit bore in the aluminum housing, which often becomes very difficult to disassemble without heating the aluminum housing. One bearing (top) must be pressed off the shaft and the replacement bearing precisely positioned where the old one was, so you need to measure with an inside snap gage, a dial caliper tail or depth micrometer to assure proper re-positioning. If you don't get it right then the motor shroud will rub the housing and the shaft won't sit right in the lower bearing.
You also need to replace the brushes while you have it apart. Between the labor, brushes and bearings cost you are better off taking it to a DeWalt service center - but even so, the cost to replace the router would usually be less than the service cost if it is out of warranty! Be very careful to make sure if you or anyone does do this job that the replacement bearings are properly rated for high speed - otherwise you'll be doing the job again in a few months of use.
Dewalt router 616
You can buy it online from DeWalt the part number is 399063-00 list price 23.74 or you might try ereplacementparts.com also. They don't show what the wire guage is or length so I can't tell you to go to an electrical supply house and get it. Good luck
Top Dryers Experts
john h
