Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
The ice
maker not working.-------------
Its the problem of water inlet valve. It's a
dual valve. This valve has two tubes in it. One for water dispenser and one
for ice maker chamber. The one side of valve is working, but other side of the
valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the
problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Your icemaker's water inlet valve could be filled with ice. If it is, simply thaw the its water tube with a hair dryer to remove the blockage. Be careful to not melt any plastic parts with the blow dryer.
An icemaker's water inlet valve has a filtering screen to block minerals and other debris from entering into your ice cubes. It is possible that the water inlet valve's screen is blocked, and not allowing any water through to make ice. Clean out any built up debris you find. You should be able to pop the screen out of place with a screwdriver and then put it back in place with the screwdriver again once it is cleaned.
Alternatively, the water inlet valve itself may have become defective. You will have to test it. If the test proves the valve is defective, replace it.
if you need more info post it and I'll see if I can locate more
please take a moment to rate my response
