On that model the conv IC is usually not the solution. I believe its the blown capacitor problem with is an easy fix. Check the site www.TvRepairKits.com for a repair kit.
SOURCE: sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
does the screen totally black or with only white screen?. recheck all the connections going to t-con board and x board which you missed.
SOURCE: How does a T-con Board works?
It is difficult to type in all here by this window, as it is too much. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
SOURCE: I have a LG 42LE5300 Led tv when I turn the tv on
if you are getting the logo and snow , I think you are on the wrong channel for programming
