SOURCE: Bernette 65 Sewing machine
As a Bernina tech I may be a bit biased on this but I can say this... If you decide on this machine be sure you get it from a dealership with an on-site technician. Any can be an Authorized dealer but not many have a Certified technician. Not to say that you will need one but if it does get an issue in can be taken care of promptly. Also Bernina dealerships are required to have a class for you on their machines. I have worked for a Bernina dealership for the past 5 years and have not had a Bernette come in for a repair. Of the reviews I've read the complaints are of the tension which seems most likely a user default such as not keeping it clean after use, using cheap thread, not understanding how to adjust it for different fabrics, the right type of needle, etc.
I like the 1 step buttonholer and the threader. I wish the lighting was better.
If your going to spend less than 200.00 on a new machine you could do much worse. If you decide to not do the Bernette consider the Janome line next. (with an on-site tech)
Good luck.
SOURCE: Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
SOURCE: Bernina Bernette 65 sewing machine
Presumably neither of you has or knows how to adjust your bobbin tension so, I'm going to presume it's your hook. Make sure you are threading the machine coorectly then you'll need to remove your needle plate by removing the two screws, pull out your hook (this is the part your bobbin sits in) but make sure you note which way it sits inside your machine. Have a look at the plastic hook for any sharp edges or burs, you may need to replace your hook or try and gently sand (400grit) the plastic if possible. The key part of the hook is the small blunted point as this is what catched the loop of thread behind the needle. Please make sure that when you put your hook back in, that it is on the left side of that little guard sticking out on the lower right of your machine.
SOURCE: Bernette sewing machine making a mess of thread on back of fabric
I once heard from a great sewing instructor that if the problem is on the back of the fabric then it is a spool to needle problem.... if the problem is on the top of the fabric, then it is a bobbin problem. Check your machine for dust and stray threads. Check your bobbin casing for dust and stray threads.
SOURCE: Please walk me thru winding the bobbin on a
Try this page for Threading and Bobbin Winding Diagrams for loads of machines.....even if your model is not specified, there's a good chance you will be able to work it out from similar machines. http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Model number?
Bernette 812
