Refrigerators Logo
C
CHRISTOPHER KALOGRIS Posted on Apr 16, 2019
FREEZER RUNS FOR APROX. 6-7 HRS .ALL IS FINE .WHEN IT GOES TO DEFROST CODE E4 APPEARS
5 Related Answers
docjohn174
john gagnon
  • 943 Answers
  • Posted on Sep 28, 2008
SOURCE: chest freezer runs almost non-stop.
hi. thanks for the question.you said you could not set the thermostat any warmer. so no matter what you do. it is not changing a thing. -5 the block of ice on the back, is a sign of too cold & running to long. was it frosted up inside the freezer i would replace the cold control thanks the appliance doc
Anonymous
  • 1902 Answers
  • Posted on Jun 02, 2009
SOURCE: Defrost Drain clogged
Take a spray bottle with VERY hot water and spray it down the drain line
Testimonial: "Good advice. Wife called repairman before I could apply. Repairman did same thing, but with pressureized."
Anonymous
  • 57 Answers
  • Posted on Jul 16, 2010
SOURCE: I get a E4 errror code.
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen.
Anonymous
  • 674 Answers
  • Posted on Oct 15, 2010
SOURCE: Brand new mpi 2200 heater...runs fine with front
Make sure the circulation fan is running. That is the one you can see on the back. Also look at the black grill. One side is open and one side will be blocked. You want the open side on your left if you are standing in front of the heater looking at it. Also look inside the heater and make sure nothing is blocking the air flow. Let me know what you find.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Aug 21, 2011
SOURCE: Kenmore Freezer 106.727581: The freezer ices
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater. To determine if the defrost heater is burned out, watch this part testing video
Russell Hobbs fridge is showing an E4 error?
Question edited for clarity and spelling of maker.
They don't actually make them, it is just their name on it.
Hotpoint Refrigerator Error Codes
Hotpoint Refrigerator Error Code E1
Refrigerator sensor fault
Hotpoint Refrigerator Error Code E2
Freezer sensor fault
Hotpoint Refrigerator Error Code E3
Defrost sensor fault
Hotpoint Refrigerator Error Code E4
Fridge defrost sensor fault
Add the model number to the search query after the word 'Hobbs'.
https://www.google.com/search?q=Russell+Hobbs+fridge+E4+error
The Thermal fuse of the defrost heater in my freezer is tripping.
what is your controller? replace fuse if needed,review your control parameter and find the e4 means.
I hear water running in my freezer and can see it dripping inside the freezer through the grate in the back panel. As this is happening the freezer will warm up to almost 32 degrees. I have to press the...
they are no longer 6 or 8 hour timers they are adaptive defrost and the more you open and close the door and the moreyouchange the settings the more often it will go into defrost. There is no set time on these models for the defrost cycle.
1helpful
Temperature in refrigerator is now at 60 degrees even with the dial at setting of 9 other side freezer is fine
sounds like the defrost system is cutting up, it melts the ice in the freezer compartment to allow cold air from freezer to travel to fresh food side and back again, could be a damper control but very rare event.we use to have to melt ice manually in freezers now we have automatic defrosters do it for us. this is not the easiest repair but the defrost sysem is replacable and not the end of your frig.u can empty frig and turn it off for 24 hrs with doors open and let it defrost naturally,so as to make sure that it is a defrostsystem, after 24 hrs turn back on and see if it works correctly after 6 or 8 hrs, if so definite defrost problem.
1helpful
LG LFC25760 not working
This error appears when the fridge goes into defrost mode (after a few hours of initial startup and therefore a sign that your PCB is probably just fine). Look into the thermostor in the freezer compartment (mine was bad, a $2 part from Radio Shack), the defrost heating element or the temperature sensor in the freezer compartment.
Kenmore elite MOD.596.76533500
Hi, If the freezer is cold............ I would suspect the defrost timer. Remove everything and place in coolers or another refrigerator. Unplug the refrigerator. With doors open let it sit for aprox 6 hrs. A fan blowing into the freezer section will help. Plug back in and see if it works good again. The fans may be caked in ice and should run again but they may have burned up and need replaced. If it works good for a couple of days and problem returns, Replace the defrost timer. Hope this helps. kstfas
Frost in "frost-free" freezer
Hi, This is my suggestion to check the defrost timer. "I would suspect the defrost timer. Remove everything and place in coolers or another refrigerator. Unplug the refrigerator. With doors open let it sit for aprox 6 hrs. A fan blowing into the freezer section will help. Plug back in and see if it works good again. If it works good for a couple of days and problem returns, Replace the defrost timer." Sound like you have already done my little test so the defrost timer needs replaced. NOTE: Refrigerators are well insulated and it takes several hours to completely defrost one so you may want to try it again. Also, I believe the clicking you hear is the fan blade hitting ice. Hope this helps. Let me know. kstfas
2answers
Freezer works, refrig isn't cooling
maybe you have incidentally disconnect the lines wire thats connect to blower, or you have blown fuse line in to blower.. check all the wires unconnected. or when the fuse blown! replace a new one fuse with same rating!
Defrost timer
The timer has a rotation 24/7 every 6 to 8 hrs. depending on timmer set up it goes into defrost... there is No way to adjust when it will defrost.
I have a cold freezer/warm fridge problem
Hi, Yes, They are the same thing. Can you hear the fan motor running in the freezer? If not it probably needs replaced. Some units shut the fan off by a door switch. If its not running when the door is closed, it could be the door switch. If the fan is ok, make sure the thermostat is set right. Sometimes something in the frige gets bumped against it and it will get moved. NOTE: Allow aprox 12-24 hours for changes in thermostat settings to take full effect. If this all checks out ok I would suspect the defrost timer. Remove everything and place in coolers or another refrigerator. Unplug the refrigerator. With doors open let it sit for aprox 6 hrs. A fan blowing into the freezer section will help. Plug back in and see if it works good again. If it works good for a couple of days and problem returns, Replace the defrost timer. Hope this helps. kstfas
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
