SOURCE: the drain for the freezer is plugged & water is draining down into the frigg
Put hot water into the drain to melt the ice and until it goes through.
9 out of ten chances its peas or french fries. i know this sounds funny but its true. depending on the model of fridge you have varys the complexity of the issue. for most fridges. you just got to start taking it apart from the inside remove all screws and make sure you mark everything so you know where they go to. its not that hard in most cases once you get behind the shell of the fridge you will see a drain pipe
SOURCE: Hoover HCA390FFK not draining through drain plug
A common problem is a blocked drain tube. Using compressed air, blow through the tube to clear it. Also, make sure that th refrigerator is level in both directions to allow proper pitch for draining.
SOURCE: drain plug by freezer coils plugged water
If the drain is clogged melt all frost or ice with hair dryer. Remove the water with a cloth. Make sure the unit is leveled. Locate the hole of the drain and run some hot (not just warm) water in to it. If it doesn’t get to the pan, run a electric wire 12 or 14 Gauge and start pushing in to the hole. Be very careful.
SOURCE: MY WHIRLPOOL FRIG FREEZER IS DRIPPING WATER IT IS
If it's something that you have someone to help assist you on the instructions I will give you yoiu will be able to get this problem solved. I realize you want bthis stopped and resolve the problem one and for all! Be back my computer needs a restart.
