Aicok Juicer 1000W - after 10 time of using it the knob stopped turning it on and off while rotating and clicking. Knob does not work.
I bought new Aicok Juicer 1000W from Amazon a month ago. I used it about 10 times. Recently the knob's position stopped corresponding the actions - for example to turn it off I had to put it into position II or I. Yesterday I could not turn it off at all at any knob's position, I had to unplug it. Today it just does not start on any knob's position. This product has poor quality and should be rated as such. How to make it work? It is sad to through away expensive juicer after 10 times of using it.
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
This juicer has a 10 year warranty and you can contact Omega directly for warranty information and servicing the juicer. The link for their website is below:
you have to twist the top round so that the switch is pressed in place so the power can be turned on, from new it takes a few times to get it to click in place this is the safety device so it cannot be turned on by mistake.
Go to Lowes, to the cabinet knob dept. Get a cabinet knob that matchs the holes in blade. You can always bend the screw a tiny bit if needed to fit. Put the screws into cabinet knob, and tighten. Cut the heads off and you are ready to go. They have a knob that is stainless steel, just a flat piece across the top, an 2 straight pieces that go down. I think it was $2.97. It gives good grip, and takes the blade right off.
I am having a similar problem, turned it on to juice carrots, it sounded like it was rotating very slowly then the motor just stopped. Would love a fix, i am addicted to my juicer and would be very sad if it was not good. It is only about 2 months old.
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
