Question about Cell Phones
I have used wrong charger on revitive now wont charge
    Top Expert:
  • 5,436 Answers
I did that with a spot light. Burned some internal parts. Take it to a phone repair center. They may be able to help.
Posted on Apr 15, 2019
2 Suggested Answers
SOURCE:
  • 4090 Answers
SOURCE: my tomtom wont charge through car charger or pc
It is possible that the cvar charger fuse has blown. Undo the tip and remove and replace !amp fuse and all should be fixed.
Please rate my help++++Thanks for using FIXYA
Posted on Dec 08, 2009
Why wont my nextbook flexx 11 charge or turn on
Take it to a repair shop!!! Never use the wrong charger on computer equipment. Damage can occur.
Sep 03, 2017 | Nextbook Tablets & eReaders
I have a mayfair freerider scooter and all of a sudden it wont charge up. charger says abnormal charge. Is there something wrong wiyh the batteries or charger?
try borrowing a charger from a friend or neighbor to charge your scooter If it charges the batteries then your charger is bad if it doesn't charge your batteries then the batteries are bad Hope this helps
Apr 17, 2011 | Universal Health & Beauty
My phone wont charge i always have to put it in a different position too get it too charge wats wrong with it?
Hi, there are two things you will need to test for ,
The charger and the charging port.
The charger of the phone might not be contacting properly causes it to fail or loose contact, that might be the reason it needs to be position properly before it charges.
You can use another charger to see how firm it will on another phone, so that you can be able to know if you will need to replace the charger with another one.
The charger port is where you plug in the charger to the phone for the phone to be able to charge.
Sometimes if the charging port is weak,itmight not be able to hold the charger properly,it will be failing contact.
Also you can use another charger to test with your phone and see how firm it holds on the phone and if it will charge the phone without failing.
I guess when you test for the charger and the charging port, problem will be solved.
Feel free to pass your comment.
Thanks for using fixya....
Jan 11, 2011 | Sanyo Cell Phones
I have had 4 pantech jest phones and it wont charge!!!! i had it plugged in then i thought it was charged fully cause the bars were full when i took it out.....BAM!!!! i shutt of!! im sick of it i had 4...
Make sure you're using the Pantech charger you got with your phone. I had this problem, got a new one, and realized I'd been using my old charger charger. Plugged it in with the wrong charger, it wouldn't work. Plugged it in with the Pantech charger, it started charging up and worked fine again.
Dec 27, 2010 | Cell Phones
My tomtom wont charge through car charger or pc
Dec 08, 2009 | Tomtom ONE 3rd Edition GPS
The Ryobi 18V battery will no longer charge in the charger.
If you have a battery that will still charge you can take the one that wont charge and place a small jumper wire in both sides of the battery. + and - Then put it in the charger. place the jumper wires + to + and - to - for one sec and you will see the yellow light go off and it will charge.
Jul 13, 2009 | Ryobi 15" Electric Factory Reconditioned...
Sidekick 3 wont charge
There might be something wrong with the charger or you can use a different outlet.
But if there is something wrong with the charger i would suggest to get a new one (:
Mar 05, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
You Blew A Circut In the Charger Port Depending On the wattage of that wrong charger. Now HeresWhat you do. you Need to find out if you blew all the circuts in the phone or just the one for the charger port, Find Some One With A Sidekick Test the battery in your phone make sure its fully charged, If your Phone Comes on the rest of the circuts are fine, if it doesnt you need a new mother board. If It Does U Need To Have the Phone Repaired. Call Me 347.845.7151
PLz Be Sure To Mark The Problem Solved
Nov 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Charging problems
umm dat mite be a prob becuz the car usually pumps more voltage in the fone...........and if too much is pumped it damage the circuit board and mite even fry the system...... be care ful and keep trying the wall charger..........hope it works
Feb 21, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
288 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
