You'll need to enter the model number of your dishwasher, on this page: http://www.candy-domestic.co.uk/en_GB/user-manual
That should pull up the correct user manual and give you the answer you are looking for.
SOURCE: HTC Touch Diamond In Italian, I Want English!!!
Go to HTC's website and go to support and select htc touch diamond (make sure its 'diamond' and not 'htc touch'!) and see if there are any rom updates (in english). Make sure it is for your phone + carrier/cell provider, as sometimes there are different rom versions, for different carriers. (depends on your country, so change the country)
SOURCE: change the language english from italian
Go to Main Menu/settings/system/Regional Settings
Change the location here. If you have the problem still then try doing
the hard reset in the same location. Once the phone restarts, then
specify your region and language.
Do remember to backup your data before doing the hard reset. I hope it helps
SOURCE: language change
Your Samsung Omnia (SGH-I900) supports only one default language. There is no way to add/change additional languages to your mobile phone.
SOURCE: I have just purchased a
OK the manual has it a little wrong.
What you have to do is switch the power off (not at the wall but on the machine itself)
then press the three buttons for around 5 seconds till you hear a beeb
next time you switch it on it will be back to the language selection
just follow the manual to select.
