Testing voltage on led connection to power supply gives a zero Volt reading between positive and Negative leads when connected to the power supply with the tv powered on. When LED plug is disconnected from power supply, Power supply has 150 Volts from the positive leads when connected to the tv case as a ground. When reconnecting the LED plug the power supply I find that if I test the positive leads from the power supply to the LED using the case as a ground I see the expected 60 to 70 Volts. Is the failure in the Power supply or the LEDs? It seems to me that the power supply has a bad ground to the LEDs. The negative leads from the power supply do not have connectivity to ground/the case. The plug itself seems fine. Thanks
SOURCE: LG TV 39LN5300 - What is normal voltage at LED connection to power supply?
ok so the problem is not with the power suppkly it is with the leds inside the panel they are in strings and usually only a few of them are your problem see the link for led prices http://www.shopjimmy.com/auo-t390hvn02-2-led-strips-8-strips.htm
Testimonial: "Had thought that it was the LEDs but with only minimal knowledge was not sure. I don't know why the voltate would be over 200 volts. As for ordering LED strips I have heard that they were panel specific, and have heard that they weren't. The link you provided is out of stock, unfortunately. Is basically any 39" strip useable or does it need to be matched to the panel? Thanks again."
